72 watt AC-DC power adapter - RadioRadar
16 years ago
Emerson Network Power has expanded its portfolio of ac-dc power adapters with the launch of a 72 watt model. The AD72 power adapter features a universal 90-264 Vac input and produces a single, fully regulated 16 Vdc output capable of delivering up to 4.5 A continuously. AD72 freestanding ac-dc power adapters provide a very flexible, pre-approved power solution for a wide variety of portable and desktop applications, including instrumentation, test and measurement systems, telecommunications and computer peripherals. The AD72 uses a high efficiency switch-mode design that complies with the Blue Angel requirement; it has a typical efficiency of 84 percent. The adapter is equipped with a 2-pin (type C8) IEC320 ac input receptacle and features an internal ac input fuse.
 The dc output is provided via a 6 ft (1.85 m) cable fitted with a standard 2.1 mm right-angle barrel plug. AD72 power adapters have a full load ambient operating temperature range of +5°C to +40°C without de-rating. The adapters are comprehensively protected against overvoltage, overpower and short-circuit conditions, with automatic recovery. They are equipped with an internal EMI filter and comply with the rigorous EN55022-B and FCC part 15 Level B EMC standards for conducted noise, and also meet applicable electromagnetic immunity standards, including EN61000-4-2 and -4 levels 2. The power adapters also carry a comprehensive set of safety approvals, including UL/CSA/NEMKO 60950-1. Pricing starts at US$35 in OEM quantities.
Other news ...
