Archive : 2010 год
27.04.2010 - 08:53
Analog Devices has created two MEMS microphones that enable advanced audio functions for portable electronics. These functions include high-fidelity audio/video playback, hands free communication, and voice recognition with built-in wind noise suppression, and TIA-920-compliance for VoIP applications. The ADMP 404 and ADMP405 iMEMS microph...
21.04.2010 - 09:03
The current version of the universal Spectrum driver comes with full Windows 7 support for the complete product range of the fast digitizers and generators with sampling rates between 100 kS/s and 1 GS/s. This driver of cause also supports earlier Windows versions like Vista, XP or 2000. After Windows Vista, being not the most successful s...
20.04.2010 - 08:52
The TXL2 transmitter and RXL2 receiver modules, from London-based wireless solutions developer Radiometrix, are half duplex multi-channel OEM radio modems offered in a SIL standard footprint. Operating in the European license-free 433 MHz ISM (Industrial Scientific and Medical) frequency band, with a choice of 5 user programmed channels, these prod...
05.04.2010 - 08:58
AMS Technologies announces a new range of laser diode controllers incorporating temperature controller from Belorussia based OEM Tech System Engineering. OEM Tech has launched a range of controllers for powering and controlling not only the laser diode but also the cooling elements for the diode. This complete solution incorporates a module for the...
04.03.2010 - 10:38
ZMDI presents 12 new members of its converter family SARah. The A/D-converters ZADC510x and ZADC512x have a Dual Core and operate with sampling rates of up to 1MSample/s. The Dual-Core enables developers to make use of applications which require the parallel sampling of 2 signals. The family, which operates on the principle of successive approximat...
04.02.2010 - 10:25
Texas Instruments introduced a 3.2-W, mono Class-D audio amp with an integrated digital-to-analog converter (DAC) noise filter that reduces codec noise by as much as 82 percent, compared to devices without this feature. 3.2-W into 4 Ohms at 5 V produces 22 percent louder audio than competing solutions with no audible pop, a common challenge in port...
29.01.2010 - 14:20
Cynergy3 Components Ltd. has introduced the 2 series sub miniature reed relays, for high voltage isolation in RF applications in the 1-30Mhz range. The reed relays use rhodium contacts in a vacuum environment, offering the best isolation voltage of 1.5kV across contacts, low contact resistance of 200mOhms and optimized lifetime of 1 x 109 dry switc...
14.01.2010 - 11:03
Xilinx announced the first shipments and availability of its Virtex-6 LX760 device. The Virtex-6 LX760 device is ideal for application that requires intensive computational performance and high logic density. The Virtex-6 LX760 device has 1,200 SelectIO pins, 758.784 logic cells and 25,920Kbits Block RAM. LX760 device is optimized to tradeoff high-...
10.01.2010 - 22:36
Analog Devices announced the availability of its ADF4158 PLL synthesizer which enables implementation of FMCW (frequency modulated continuous wave) radar systems. FMCW radar systems are used in automotive, aerospace, military, industrial and communications applications to remotely measure the relative distance and speed of external objects.&nbs...
