Archive : March 2017 год
27.03.2017 - 23:30
To demonstrate flexible, printable electronics that combine sensors and processing circuitry, MIT researchers have designed and built a device that responds to mechanical stresses by changing the colour of a spot on its surface.According to the research team, covering a robot or plane with sensors will require a technology that is both flexible...
25.03.2017 - 23:56
Global distributor Arrow Electronics is making available a FPGA IoT Maker Board. Designed for end-to-end application development and optimised for cost, the MAX1000 board can be installed directly into a custom application or integrated on to a separate boardIntended for use by start-ups, universities or established equipment manufacturers who...
25.03.2017 - 23:51
A research group from Korea’s Institute of Basic Science has devised a disordered arrangement for antennas, which is said to minimise redundancy and to enable each antenna to function independently. As a result, the device is said to provide 40 times wider bandwidth than periodically arranged antennas."We are proposing a new way to c...
19.03.2017 - 23:19
A sensor developed at the University of British Columbia (UBC) could help make advanced transparent and stretchable devices a reality.The sensor uses a highly conductive gel sandwiched between layers of silicone. This allows different types of touch to be detected, including swiping and tapping, even when it is stretched, folded or bent....
19.03.2017 - 23:15
Chip stacks could be supplied with electrical power by integrated flow batteries and cooled at the same time, according to research undertaken by ETH Zurich and IBM Research Zurich.In flow batteries, electricity is produced by an electrochemical reaction between two liquid electrolytes which are pumped into the battery cell through a closed loo...
19.03.2017 - 22:52
Bosch and NVIDIA are collaborating to develop artificial intelligence self-driving systems targeted at mass market cars. The system, which will be built on NVIDIA’s deep learning software and hardware, is intended to enable vehicles to be trained on the complexities of driving, operated autonomously and updated over the air with new features...
19.03.2017 - 22:47
Lynx Software Technologies has demonstrated its LynxSecure Separation Kernel hypervisor on the Xilinx Zynq Ultrascale+ MPSoC at Embedded World. It is the first view of LynxSecure on an ARM Cortex A-53 processor and is, according to the company, a significant milestone for designers of ARM-based automotive, avionics, industrial and medical devices....
19.03.2017 - 22:43
Analog Devices has unveiled an ultra low power microcontroller unit (MCU) that looks to address the growing need for embedding advanced algorithms while consuming the lowest system power at Internet of Things (IoT) edge nodes.The ADuCM4050 MCU includes an ARM Cortex-M4 core with floating-point unit, expanded SRAM, and embedded flash memory in o...
09.03.2017 - 23:33
US company Nanomedical Diagnostics has worked with MEMS foundry Rogue Valley Microdevices to deliver what is said to be the first mass produced graphene based biosensor.Called the AGILE R100, the benchtop device is designed to provide biophysical data to pharmaceutical and biotherapeutics companies seeking more informed decisions earlier in the...
09.03.2017 - 23:28
Qualcomm Datacenter Technologies (QDT) is working with Microsoft to accelerate next generation cloud services, using its 10nm Centriq 2400 platform. According to the partners, the collaboration will span multiple future generations of hardware, software and systems.QDT has also submitted the Centriq 2400 Open Compute Motherboard server to the O...
