Archive : March 2007 год
19.03.2007 - 11:40
The MAX9724A/MAX9724B stereo headphone amplifiers are designed for portable equipment where board space is at a premium. These devices use a unique, patented† DirectDrive™ architecture to produce a ground-referenced output from a single supply, eliminating the need for large DC-blocking capacitors, saving cost, board space, and compone...
19.03.2007 - 11:21
Fluke announces the Fluke 771 Milliamp Process Clamp Meter, which measures 4-20 mA output signals from transmitters in process and industrial control system applications without breaking the current loop. The Fluke 771 Milliamp Clamp Meter delivers 0.2 % accuracy with resolution and sensitivity to 0.01 mA for testing and troubleshooting PLC (progra...
16.03.2007 - 11:01
DALLAS, TX—March 15, 2007—Dallas Semiconductor, a wholly owned subsidiary of Maxim Integrated Products (NASDAQ: MXIM), introduces the DS2792 programmable fuel gauge for 1- or 2-cell applications. Integrated into the DS2792 are a MAXQ® microcontroller; generous program and data memory; and an accurate measurement system for bat...
16.03.2007 - 10:54
Optional LogWare III supports Ethernet, 802.15.4 wireless, RS-232, email messaging services and as many “DewKs” as can be put on a networkHart Scientific, a division of Fluke Corporation and the world leader in temperature calibration products and services, announces the new Hart Scientific 1620A paperless temperature and humidity d...
15.03.2007 - 11:12
Fluke designed as a tool for servicing and commissioning electronic switching loads including variable frequency drives, electronic lighting and uninterruptible power supply (UPS) systems. Combining the functionality of a power quality meter, oscilloscope and data logger, the Fluke 345 features a convenient clamp-on design for measuring the most co...
15.03.2007 - 11:06
he MAX3222E/MAX3232E/MAX3237E/MAX3241E/MAX3246E +3.0V-powered EIA/TIA-232 and V.28/V.24 communications interface devices feature low power consumption, high data-rate capabilities, and enhanced electrostatic-discharge (ESD) protection. The enhanced ESD structure protects all transmitter outputs and receiver inputs to ±15kV using IEC 1000-4-2...
15.03.2007 - 10:58
EL SEGUNDO, Calif. — International Rectifier, IR®(NYSE: IRF), a world leader in power management technology, today introduced the IR3651, a synchronous PWM control IC designed for high performance synchronous DC-DC buck applications with an input voltage range up to 75V. With programmable switching frequency up to 400kHz, the IR3651 is id...
15.03.2007 - 10:31
EL SEGUNDO, Calif. - International Rectifier, IR® (NYSE: IRF), a world leader in power management technology, today introduced two new POWIR+™ chipset reference designs, the IRPP3624-05A and IRPP3624-12A. Simplifying and accelerating circuit design, the new reference designs target single-phase synchronous buck converter applications in c...
15.03.2007 - 10:21
EL SEGUNDO, Calif. - International Rectifier, IR®(NYSE: IRF), a world leader in power management technology, today introduced a new chipset in their XPhase® family of control ICs and phase ICs for scalable multi-phase, interleaved buck DC-DC converters, adding N+1 redundancy, hot-swapping capability and a host of protection features. IR&rsq...
