Archive : February 2008 год
29.02.2008 - 09:41
Chomerics Europe has been able to provide a solution to a thermal management application encountered on an automotive ECU using its silicone-based Therm-A-GAP T630G dispensable form-in-place gap filling material. Previous approaches considered included thermal interface pads, which can be expensive both in terms of component and assembly cost, and...
29.02.2008 - 09:39
Linear Technology introduces the LTC2919, a versatile triple supervisor that monitors its own supply voltage and two adjustable inputs. Polarity selection and a buffered reference output allow the LTC2919 to monitor a combination of two positive or negative supplies for undervoltage (UV) and overvoltage (OV) conditions. The two inputs have a nomina...
28.02.2008 - 10:33
Phyworks has announced a fully 10GBASE-LRM compliant serial retiming receiver with Electronic Dispersion Compensation (EDC). Manufactured on a CMOS process, this second-generation EDC chip offers a powerful equaliser. The PHY2060 enables upgrade of X2 and XFP optical modules and SFP+ based line cards to true 10Gbps LRM operation.Combining clock dat...
28.02.2008 - 10:31
Luminary Micro announced communications modules and reference design kits for Ethernet-enabled display applications and serial-to-Ethernet communications applications. Based on Luminary Micro’s real-time Stellaris microcontrollers, the communications modules and accompanying reference design kits provide OEMs with a production-ready solution...
28.02.2008 - 10:29
  Seoul Semiconductor announced the development of the ultra bright LED, Z-Power P7 Series. The Z-Power P7 Series, which the company started producing in volume quantities today, delivers brightness of 900 lumens at 10 watt. The 10W P7 single LED package produces luminous flux of 900 lumens. The Z-Power P7 Series has an efficacy o...
26.02.2008 - 13:31
ON Semiconductor introduced a GreenPoint open reference design for a 16 watt (W) ac-dc adapter for xDSL modems. This design exceeds ENERGY STAR requirements for single voltage ac-dc and ac-ac external power supplies revision 1.1, for high active-mode power efficiency and low standby-mode power consumption. The reference design can also be modified...
26.02.2008 - 13:29
Actel announced the addition of two members to its IGLOO and ProASIC3 field-programmable gate array (FPGA) families starting at just 99 cents. Comparable in density to 128 macrocell complex programmable logic device (CPLD) offerings, the 15,000-gate devices offer power consumption as low as 5 microwatts (5µW). The FPGAs provide a alternative...
26.02.2008 - 13:27
Schurter’s 20A IEC inlet with EMI filter, series 5130 ECO design, meets the of IT, medical and industrial appliances. The 5130 combines an IEC C20 inlet with line filter in various mounting styles. The positive electrical contact of the broad metal flange to the chassis ensures optimal filtering and shielding. The units are available with cur...
26.02.2008 - 13:26
Maxim Integrated Products introduces the MAX13410E–MAX13415E* half-duplex, RS-485/RS-422 transceivers with an integrated low-dropout (LDO) regulator. These transceivers utilize Maxim's proprietary AutoDirection control architecture to automatically enable the driver when transmitting data. AutoDirection control thus eliminates the need fo...
25.02.2008 - 09:35
AnalogicTech has introduced two mini-Power Management Units (PMUs) that combine three step-down DC/DC converters in a single monolithic IC. Targeted at portable devices with rapidly evolving feature sets, the 3-channel AAT2784 and AAT2785 allow designers to add one 1.5A synchronous step-down converter and two 300mA synchronous step-down converters...
