Archive : September 2008 год
29.09.2008 - 08:01
Xilinx announced a single-FPGA solution for telecommunications equipment manufacturers developing 40- and 100-Gigabit Ethernet (GE) solutions. Xilinx has added the Virtex-5 TXT platform to its family of 65-nanometer FPGAs. The platform consists of two devices that deliver 6.5Gbps serial transceivers, and are fully supported with application-specifi...
26.09.2008 - 08:05
Schurter’s IEC C14 inlet with EMI filter, series 5120 ECO design, meets the demands of IT, medical and industrial appliances and is now also available as snap-in mounting version. The series combines an IEC C14 or C18 inlet with line filter in various mounting styles. The EMI filter is dimensioned as a 1-stage filter for rated currents up to...
25.09.2008 - 07:42
The PR4404 from Prema is a LED driver providing more than 150mA out of one battery cell and up to 300mA from two batteries for one to three power LEDs. A hold input allows controlling the LED brightness via a PWM signal or switching the LED from a microcontroller. Several applications and circuits can be found in the comprehensive data sheet on the...
24.09.2008 - 08:07
Matrox Concord GigE is a new family of interface cards that are pre-licensed for use with the Matrox Imaging Library (MIL) and pre-configured to minimize application setup time. The single-port Matrox Concord GigE is factory-configured to maximize the size of jumbo packets and manage interrupt moderation and receive descriptors for optimal GigE Vis...
22.09.2008 - 09:02
Maxim introduces the MAX4889B/MAX4889C, 1:2 or 2:1 PCI Express (PCIe) passive switches. The quad double-pole/double-throw (DPDT) switches are for switching four half lanes of PCIe data between two destinations. Four devices can be used to convert 16 PCIe lanes into two sets of 8 lanes for use with either SLI or CrossFire graphics cards.The MAX4889C...
19.09.2008 - 08:18
With the Microspace MSM200X/XL/XP based on the Intel Atom processor, the Swiss-based company Digital-Logic is extending its range of PC/104-Express single board computers. The board is used for applications in battery powered mobile computers, information terminals with video displays, game systems with music output, measuring instruments or teleco...
18.09.2008 - 08:15
Eurotech announces the Isis PC/104+ board based on the Intel Atom processor. The processor is matched with an Intel System Controller Hub (SCH) US15W which is a device combining a graphics memory controller and I/O controller into a single 22x22 mm package. A full range of on board peripherals are provided including 8 x USB 2.0 ports, VGA, LVDS, HD...
17.09.2008 - 08:32
Chomerics Europe has introduced a thermal grease designed to conduct heat between hot components and heatsinks or equipment enclosures. T670 is a silicone based material with a high bulk thermal conductivity of 3W/m-k. T670 can be screen printed, stencilled or dispensed and requires virtually no compressive force to achieve excellent surface wettin...
16.09.2008 - 08:16
Maxim Integrated Products introduces the MAX9938, a high-side, current-sense amplifier. It integrates precision resistors to minimize total solution size, eliminating the need for external gain-setting resistors. The MAX9938 features a ±0.5mV (max) VOS and 0.5% (max) gain error, for a total error of less than 1% (max). Additionally,...
15.09.2008 - 08:45
ON Semiconductor has introduced the NCP5890 – a lighting management device that integrates LCD backlighting, fun light controls and ambient light sensing into a 3 mm x 3 mm x 0.5 mm package. With its 30-volt (V) output capability, the device drives LEDs in series to achieve homogeneous backlight over the LCD screen. In addition, the NCP5890 c...
