Archive : August 2008 год
22.08.2008 - 09:06
Linear Technology announces the H-Grade version of the LT3481. The LT3481 is a 34V (36V(MAX)), BurstMode, step-down switching regulator that maintains quiescent current under 50uA.The "H" Grade version operates up to a junction temperature of 150°C, compared to the "E" and "I" Grade versions' 125°C maximum...
20.08.2008 - 08:44
National Instruments announced the NI PXI-8108, a PXI embedded controller, and two new PXI system accessories, a 32 GB solid-state hard drive and the NI PXI-8250 system monitoring module. The PXI-8108 embedded controller, which features an Intel Core 2 Duo T9400 processor, is designed for high-performance PXI and CompactPCI systems. With its 2.53 G...
12.08.2008 - 08:32
Sharp is presenting an enhanced range of LED backlit liquid-crystal panels for industry applications. The portfolio now incorporates five displays in the screen diagonals of 3.5 to 15 inches. The displays combine the high resilience required of industrial applications with the benefits of a LED backlight. These include, among others, the prompt res...
06.08.2008 - 10:25
Renesas Technology Europe announced the availability in Europe of the RJK0383DPA, a dual-type power MOSFET for synchronous rectification DC/DC converters. The device achieves higher power supply efficiency and can be used for memory or ASICs in products such as laptop PCs and communication devices. Sample shipments will begin in October 2008. RJK03...
06.08.2008 - 10:18
Maxim Integrated Products introduces the DS7505 ±0.5°C accurate, digital temperature sensor and thermostat with nonvolatile memory (EEPROM). The integration of nonvolatile EEPROM enables this device to power-up with a user-defined configuration and thermostat thresholds, whereas other similar devices store threshold and configuration dat...
