Archive : July 2009 год
31.07.2009 - 08:12
Yageo released its PF1206 current sensor designed for mini portable device applications. Featuring a resistance range of 1 to 50 milli-ohms and temperature coefficient of 75ppm/ºC, Yageo's PF1206, manufactured using in-house metal foil and metal alloy processing technologies to combine PCB substrate and resistance foil, is capable of deliverin...
28.07.2009 - 10:06
To add a third protective element to fuses and filters, Schurter now also offers overvoltage protection components, thereby making it possible for users to obtain all components required for the electrical protection of their electronic appliances from one source. The company offers radial leaded varistors, also referred to as MOV (Metal Oxide Vari...
22.07.2009 - 00:14
Diodes has expanded its MOSFET offering with the introduction of 15 new devices designed specifically for LCD TV and monitor backlighting markets. Provided in industry standard TO252 and SO8 packaging, these MOSFET devices deliver the high-power handling and fast switching that are required by high efficiency Cold Cathode Fluorescent Lamp (CCFL) dr...
07.07.2009 - 09:02
STMicroelectronics brings two 512-Kbit devices that offer as the company stated the highest density memories available in the industry-standard 2 x 3 x 0.6mm 8-pin Micro Leadframe Package (MLP). The new devices are the M95512 featuring a 20MHz SPI port, and the M24512 with an I2C interface supporting 400kHz Fast-mode or 1MHz Fast-mode Plus...
