Schurter’s IEC C14 inlet with EMI filter, series 5120 ECO design, meets the demands of IT, medical and industrial appliances and is now also available as snap-in mounting version. The series combines an IEC C14 or C18 inlet with line filter in various mounting styles. The EMI filter is dimensioned as a 1-stage filter for rated currents up to 15 A with a leakage current standard < 0.5 mA and medical < 5 microampere. The positive electrical contact of the broad metal flange to the chassis ensures optimal filtering and shielding. Mounting options include screw-on, rivet or snap-in mounting. The snap-in mounting as well as the screw-on version from rear side with its pre-formed threaded holes reduces labor costs. The connection is made with quick-connect terminals. The series is ENEC and cURus approved and complies with IEC/EN standards for office and medical equipment, 60950 and 60601-1 respectively.
Technical Features
Appliance inlet IEC C14 or C18 acc. to 60320 with EMI filter
Current ratings up to 10 A at 250 VAC (ENEC/UL/CSA) or 15 A at 125/250 VAC (UL/CSA)
Screw-on or rivet mounting from front or rear side / Snap-in mounting
Standard or medical version
Version for enhanced withstand voltage available (X1, Y1)
