Archive : 25 February 2008 год
By offering designers three independently-controlled switching regulators sized to power a processor core, an I/O and a DSP, ASIC or RF circuitry in a single compact package, the AAT2784 and AAT2785 combine the advantages of functional integration, including simpler component selection, reduced BOM, minimised PCB requirements and shorter time-to-market, with the flexibility and electrical performance of a discrete approach. Designed for portable applications, the AAT2784 and AAT2785 operate off an input voltage range of 2.7 to 5.5V. Outputs are adjustable from 0.6V to VIN. Both devices employ a unique low noise architecture that reduces output ripple by 25% and spectral noise by up to 50%. With efficiency levels exceeding 95%, the new devices help reduce power consumption and extend battery life. Quiescent current is a low 50microA per channel. Transient response time is typically < 20micro seconds. Each of the three regulators in the AAT2784 and AAT2785 has an independent enable pin. A high 1.8MHz switching frequency helps minimise the size of external components and reduce PCB footprint. An integrated internal soft start function limits current surge at the input and eliminates output voltage overshoot.
Both devices also feature over-temperature and current-limit protection. The AAT2784 and AAT2785 are qualified across the -40 C to +85 C temperature range. Both ICs are available in a Pb-free, 16-pin TDFN34 package.
Other features of Intersil’s AC-driven RTCs include an automatic crystal oscillator backup in case the AC line frequency is lost (ISL12032); an integrated trickle charger that allows a rechargeable energy source such as a super capacitor or rechargeable battery to be used as a backup supply; dual alarms for reporting problems with system performance; a power status “brownout” alarm that allows the system to save vital information to memory before a complete power loss occurs; time stamp, which records the time and date of events including power loss, recovery, and tampering, a feature particularly important in metering devices; and a battery status monitor that provides warning if battery voltage drops below a certain threshold. The ISL12030 is available now in an 8 Ld SOIC, and the ISL12032 is available now in a 14 Ld TSSOP.
Source: www.channel-e.biz
Bookham announced a fully Telcordia qualified tunable small form factor transponder (TSFF). The TSFF has passed more than 2,000 hours of testing - proving its reliability and performance in a footprint 58% smaller than previous generation tunable LFF (large form factor) transponder products. The 2.2" x 3" footprint enables network equipment manufacturers to increase port density, placing two SFF transponders on a card where only one LFF would fit. A variable optical attenuator (VOA) can be integrated into the co-planar receiver package within the transponder, extending the operating dynamic range of the Rx chain to powers greater than 8dBm, and easing network design constraints. An extended band transmitter with 100 50GHz spaced ITU channels is also available, enabled by the Bookham DSDBR tunable laser chip.
