Archive : 4 February 2008 год
10:08TFT panels are compatible with Wide XGA
Seiko Epson has begun production of 0.74 inch (1.9 cm diagonal) and 0.56 inch (1.4 cm diagonal) high-temperature polysilicon (HTPS) TFT panels for 3LCD front projectors compatible with wide XGA (WXGA). The panels are compatible with 1280 x 800 dot resolution, which offers data volumes approximately 1.3 times higher than XGA (1024 x 768 dots). Commercialization of WXGA panels in two types - 0.56 inch and 0.74 inch - will enable the creation of WXGA compatible projectors in the 2000 to 3000 lumen class or higher.
10:07EMC shielded metric cable connector
FCI has increased its range of special cable connectors with the development of a Sofix connector with improved EMC shielding effectiveness. The connector is a metric cable connector for signal transmissions in telecom or industrial applications. The connector is an RoHS-compliant, 72 position I/O solution with 2mm spacing range and the capability to handle harsh electrical and mechanical environments. This product ensures an improved shielding effectiveness to reduce EMC emission and reception. This is done by the use of strong inner and outer ferules fixed between the two covers. The continuity of the grounding from cable to system frame ensures stable shielding as requested by the customer application. The covers also protect the connector from radiation and reception. FCI can adopt this shielded cable solution to customer needs.
