Boron nanotubes are stronger than carbon nanotubes
9 years ago
Carbon nanotubes are legendary in their strength - at least 30 times stronger than Kevlar by some estimates. When mixed with lightweight polymers such as plastics and epoxy resins, the tiny tubes reinforce the material, like the rebar in a block of concrete, promising lightweight and strong materials for airplanes, spaceships, cars and even sports equipment.
While such carbon nanotube-polymer nanocomposites have attracted enormous interest from the materials research community, a group of scientists now has evidence that a different nanotube, made from boron nitride, could offer even more strength per unit of weight.
Boron nitride, like carbon, can form single-atom-thick sheets that are rolled into cylinders to create nanotubes. By themselves boron nitride nanotubes are almost as strong as carbon nanotubes, but their real advantage in a composite material comes from the way they stick to the polymer.
"The weakest link in these nanocomposites is the interface between the polymer and the nanotubes," said Changhong Ke, associate professor in the mechanical engineering department at the State University of New York at Binghamton. “If you break a composite, the nanotubes left sticking out have clean surfaces, as opposed to having chunks of polymer still stuck to them. The clean break indicates that the connection between the tubes and the polymer fails.”
The researchers tested two forms of polymer: epoxy and poly(methyl methacrylate), or PMMA. They found that the epoxy-boron nitride nanotube interface was stronger than the PMMA-nanotube interface. They also found that both polymer-boron nitride nanotube binding strengths were higher than those reported for carbon nanotubes – 35% higher for the PMMA interface and approximately 20% higher for the epoxy interface.
Boron nitride nanotubes likely bind more strongly to polymers because of the way the electrons are arranged in the molecules. In carbon nanotubes, all carbon atoms have equal charges in their nucleus, so the atoms share electrons equally. In boron nitride, the nitrogen atom has more protons than the boron atom, so it hogs more of the electrons in the bond. The unequal charge distribution leads to a stronger attraction between the boron nitride and the polymer molecules. This was verified by molecular dynamics simulations performed by Dr Xianqiao Wang's group at the University of Georgia.
Boron nitride nanotubes are also said to be more stable at high temperatures than carbon nanotubes and they can better absorb neutron radiation, both advantageous properties in the extreme environment of outer space. In addition, boron nitride nanotubes are piezoelectric, which means they can generate an electric charge when stretched. This property means the material offers energy harvesting as well as sensing and actuation capabilities.
There is a drawback to boron nitride nanotubes: the cost. Currently they sell for about $1000 per gram, compared to the $10 to 20 per gram for carbon nanotubes. However, Ke is optimistic that the price will come down, noting that carbon nanotubes were similarly expensive when they were first developed.
Pic: Researchers tested the force required to pluck a boron nitride nanotube (BNNT) from a polymer by welding a cantilever to the nanotube and pulling. The experimental set-up is shown in a schematic on the left and an actual image on the right.
Tom Austin-Morgan
Other news ...
