Archive : 22 October 2014 год
With Ratings to 85 A and Power to 1600 W, Device Offers Convenient Drop-in Replacement for Competing Solutions
MALVERN, Pa. - Oct. 22, 2014 - Vishay Intertechnology, Inc. (NYSE: VSH) today introduced a new stud-mount version of its edgewound power resistor. Providing a convenient drop-in replacement for competing solutions, the EDGS combines a high-reliability design with continuous duty operation up to 85 A and a short-time overload of 10x rated power for five seconds.
The Vishay Milwaukee EDGS (a product line of Vishay Dale Resistors) features a resistance-alloy ribbon wire that is coiled on edge and supported on specially designed porcelain insulators, which provide proper turn-to-turn spacing and insulation from threaded stud mounts. The device's open-coil construction allows for efficient heat dissipation and easily accommodates overloads and surges. The EDGS's terminals are welded to the resistive wire for a reliable electrical connection.
With current ratings from 17.2 A to 85 A and power ratings from 400 W to 1600 W, the EDGS is optimized for pre-charge, discharge, dynamic braking, load testing, and heater applications in industrial drives, locomotives, wind turbines, and harmonic filters. The edgewound, RoHS-compliant device features a wide resistance range from 0.053 Ω to 5.44 Ω, with tolerance of ± 10 %.
Customizable, the industrial power resistor released today can be mounted on brackets supplied by Vishay Milwaukee or in IP-rated enclosures. The device is also available in a universal-mounted version: the EDGU.
Samples and production quantities of the EDGS are available now, with lead times of four weeks for larger orders.
Source: www.vishay.com.
Over 4,000 design engineers will be gathering at the Electronics Design Show in Coventry over the next two days to learn about the latest innovations and trends shaping this fast moving sector.
Taking place alongside the Engineering Design Show and the Embedded Design Show between 22-23 October, this two-day event will offer delegates the chance to gain access to some 200+ market leading suppliers and learn about the latest technologies, techniques and strategies employed by experts at the forefront of their field.
Those signed up to address the conference and workshop sessions comprise representatives from some of the UK's most illustrious names, including Raspberry Pi, Altium, RS Components, Cambridge Consultants, IBM and Zuken,
If you haven't already registered to attend this unmissable event, you can still do so for FREE by visiting www.electronicsdesignshow.co.uk.
For live updates during the Show, don't forget to follow @ElecDesignShow on Twitter. Use the hashtag #ElecDesignShow throughtout the Show and we'll RT you.
Laura Hopperton
