Archive : 14 February 2008 год
10:49Power Metal Strip Resistors for 275°C
Vishay announced two high-temperature, surface-mount Power Metal Strip resistors in 3921 and 5931 case sizes to offer an operating temperature range of –65°C to +275°C. The proprietary construction of the WSLT3921 and WSLT5931 devices incorporates a solid metal iron-chrome alloy resistive element with low TCR (<20PPM/°C) and specially selected and stabilized material for high-temperature capability. The devices are suited for all types of current-sensing, voltage division, and pulse applications, including switching and linear power supplies, instruments, and power amplifiers in automotive electronic controls such as engine and chassis controls, driver information electronics and climate controls; and industrial controls, including down-hole test/measurement equipment for oil/gas well drilling.
The WSLT3921 resistor measures 0.394in. by 0.205in. [10.0mm by 5.2mm] with a maximum height profile of 0.020in. [0.5mm], and the WSLT5931 resistor measures 0.591in. by 0.305in. [15.0mm by 7.75mm] with a height profile of 0.020in. [0.5mm]. A proprietary processing technique produces low resistance values ranging from 0.001Ω to 0.004Ω with tight tolerances of 1.0% and 5.0%. Like all Power Metal Strip resistors, the new devices released today feature an all-welded construction that contributes to their superior electrical performance. The WSLT3921 and WSLT5931 provide very low inductance of <5ηH, excellent frequency response to 50MHz, and low thermal EMF (<3μV/°C).
