Archive : 21 December 2007 год
Quiescent current is less than 6microAmps. The device features an intelligent digital thermal loop charge reduction circuit that optimises battery charge rate by constantly measuring die temperature and adjusting the charge current to compensate for thermal conditions. The charger IC features a programmable charge termination current feature that sends the device into sleep mode if the charging current dips below a pre-defined threshold. An integrated programmable charge timer can be used to shut down charging functions if a defective battery cell or a disconnection to the battery current path is detected. The AAT3663 continuously monitors battery temperature and charge state for fault conditions. To protect the charging device and the battery under charge, integrated over-temperature, short-circuit, over-voltage and over-current protection circuits automatically shuts down the device if a fault occurs. Specified for operation across the -40 C to +85 C temperature range, the AAT3663 is available in a thermally enhanced 14-pin, 3x3mm TDFN package.
Linear Technology expands the RS422/RS485 transceiver product family with an "H-grade" option designed for high temperature applications. LTC285xH versions feature an extended operating temperature of -40°C to 125°C.
Linear offers a wide selection of LTC285xH transceivers. Select models feature slew rate limiting, while others include a receiving logic-selectable 120Ohm termination. All devices are designed to operate in systems with 3.3V or 5V supplies, possess a maximum data rate of 20Mbps and maintain a high input impedance capable of supporting up to 256 nodes. In addition, enhanced ESD protection guarantees that no damage or latchup can occur up to ±15kV HBM.
The LTC285x family has a variety of ordering options. Aside from the H-grade version, "C" and "I" versions offer more relaxed operating temperature ranges, from 0°C to 70°C and -40°C to 85°C, respectively. Half-and full-duplex versions are available as well. Industry-standard packages include an 8-lead 3mm x 3mm DFN, SO-8, MSOP-10 and SSOP-16, all of which are RoHS compliant. Pricing starts at $1.91 each in 1,000 piece quantities.
