Archive : 24 October 2007 год
Toshiba Electronics Europe (TEE) has announced a line of camera modules featuring its Dynastron image sensor technology. This family of camera modules, which includes the TCM9200MD, TCM9100MD and the TCM9000MD, were developed using Toshiba’s chip scale camera module (CSCM) manufacturing technology and are the first to use through chip via (TCV) technology. CSCM allows mounting and assembly of camera module components during Toshiba’s wafer manufacturing process. This delivers an approximate 64 percent reduction in module size in comparison to other modules using the same sensor.
In addition to allowing camera module components to be integrated in the wafer, Toshiba’s TCV technology uses a chip structure with built-in pass through electrodes and solder balls on the rear of the wafer. Accordingly, CSCM camera modules have tighter pixel pitch leads and require no wire bonding space, yielding a smaller overall module size. Mass production for the TCM9200MD, TCM9100MD and TCM9000MD camera modules is planned for January, February and June 2008 respectively.
Source: www.channel-e.biz
Features
Transformers recommended by Analog Devices for use with ADM2485 transceiver
Low profile device offers 2.5kVrms isolation and industrial temperature operation
Accurately controlled turns ratio for consistent performance
Toroidal construction maximises efficiency and reduces EMI
Each device in the 782485 converter transformer series has been specifically designed for use with the Analog Devices ADM2485 high speed, isolated differential bus RS-485 transceiver. Fully approved by Analog Devices, the transformers are also recommended in the company’s ADM2485 datasheets and reference design documentation. The transformers are supplied in a low profile (6.35mm), fully encapsulated package with an industry standard DIL pinout. Surface mount versions will be available soon. Incorporating an internal transformer driver, the Analog Devices ADM2485 is deployed in isolated RS-485 and RS-422 interfaces as well as Profibus networks, industrial field networks and multipoint data transmission systems. Combining the device with a Murata Power Solutions 782485 transformer, an LDO regulator and a small number of discrete components allows designers to implement a fully isolated 5V power supply.
