Archive : 18 April 2007 год
11:59IP Module
Main Features:
IP module can be used to be one channel network digital video server. Also IP module with only compression board can be combined into camera and speed dome to build IP camera and IP dome. More video technology can be added on this platform. Current DVR, NVR  and NVMP software are compatible with IP module.
☉1 channel H.264 video compression.
☉Support 4CIF/2CIF/CIF/QCIF real time compression.
☉Support dual compression stream.
☉Support motion detection.
☉Support both variable bit rate and variable frame rate.
☉Support TCP, UTP, RTP, Multicast, DHCP, PPPoE and HTTP, etc.
☉Support watermark.
☉Support PTZ control.
☉Motion, sensor and other events can be sent to remote host center.
11:52NV600XHC/HF
Features & Functions :
☉ High speed & high compression ratio of H.264 video hardware real-time compression;
☉ Multiple security level leads to high system safety;
☉ Supports one RS-485 interface that can be used to control pan-tilt-zoom and translucent channel input;
☉ Support multi-areas motion detection
☉ Supports  Max CIF resolution (NV 6001 HC & NV 6004HC) real time; QCIF,CIF,2CIF, DCIF,4CIF ca be selected for NV 6001HF;
☉ Supports OSD the position of the date and time, hue can be adjusted, date and time can be
added automatically;
☉ Supports LOGO, the position of it can be anywhere in the video image;
☉Supports watermark;
☉ Supports TCP/IP,RTP/RTCP、DHCP、PPPOE、HTTP、DNS protocol;
☉Supports parameter setting, real time video & audio previewing, status examination, alarm through network and store the compression bit rate through network.
☉ Support dynamic broadband dialup in;
☉ Supports pan-tilt-zoom control as the turn of PTZ, the corresponding parameters cameras like
the size of lens and focus;
☉ Supports remote upgrading and maintenance;
☉ RS-485 interfaces support transparent transmission mode, and remote hosts can control serial
devices through the RS-485
☉ To set video server parameters through RS-232 serial ports;
Application :
It can be used to many fields like security Surveillance, transportation Surveillance, industry Surveillance, home Surveillance. For example:
Network Surveillance for ATM machines, counters in the bank, supermarkets and factories.
Network Surveillance for prisons, kindergartens, and schools.
No-man on duty system for electricity station and telecom base.
Intelligentized gate safeguard system.
Intelligentized building and community management system.
Product-line Surveillance and storehouse management.
24 hours supervising for transportation.
Network Surveillance for forest, waterhead and rivers.
Surveillance for outside devices.
