EMC shielded metric cable connector
FCI has increased its range of special cable connectors with the development of a Sofix connector with improved EMC shielding effectiveness. The connector is a metric cable connector for signal transmissions in telecom or industrial applications. The connector is an RoHS-compliant, 72 position I/O solution with 2mm spacing range and the capability to handle harsh electrical and mechanical environments. This product ensures an improved shielding effectiveness to reduce EMC emission and reception. This is done by the use of strong inner and outer ferules fixed between the two covers. The continuity of the grounding from cable to system frame ensures stable shielding as requested by the customer application. The covers also protect the connector from radiation and reception. FCI can adopt this shielded cable solution to customer needs.
