Thermal interface material
The Bergquist Company announces the availability of Sil-Pad 1200. It is a silicone based fiberglass-reinforced thermal interface material, featuring an optional adhesive coating. The material's smooth and non-tacky surfaces allow for easy re-positioning and error reduction in assembly. Sil-Pad 1200 is supplied without a liner in dry form and on a carrier liner when supplied with optional adhesive coating. Exceptional thermal performance is exhibited across a range of application pressures.
Excellent cut through resistance, facilitated dispensing and low interfacial resistance makes it ideal for applications such as: power supplies, motor controls, automotive electronics, telecommunications and placement between an electronic power device and its heatsink. Designed for applications where electrical isolation is critical, Sil-Pad 1200 also has a 6000V breakdown threshold and excellent ‘wet out’ performance. It is available in sheets, rolls, die-cut parts of any shape or size and slit-to-width roll form, with a standard thickness of 0.009" (0.229 mm). Standard sheet size is 12" x 12" (305mm x 305mm), and the standard roll size offered is 12" x 250' (305mm x 76m).
