NV600XHC/HF
Features & Functions :
☉ High speed & high compression ratio of H.264 video hardware real-time compression;
☉ Multiple security level leads to high system safety;
☉ Supports one RS-485 interface that can be used to control pan-tilt-zoom and translucent channel input;
☉ Support multi-areas motion detection
☉ Supports Max CIF resolution (NV 6001 HC & NV 6004HC) real time; QCIF,CIF,2CIF, DCIF,4CIF ca be selected for NV 6001HF;
☉ Supports OSD the position of the date and time, hue can be adjusted, date and time can be
added automatically;
☉ Supports LOGO, the position of it can be anywhere in the video image;
☉Supports watermark;
☉ Supports TCP/IP,RTP/RTCP、DHCP、PPPOE、HTTP、DNS protocol;
☉Supports parameter setting, real time video & audio previewing, status examination, alarm through network and store the compression bit rate through network.
☉ Support dynamic broadband dialup in;
☉ Supports pan-tilt-zoom control as the turn of PTZ, the corresponding parameters cameras like
the size of lens and focus;
☉ Supports remote upgrading and maintenance;
☉ RS-485 interfaces support transparent transmission mode, and remote hosts can control serial
devices through the RS-485
☉ To set video server parameters through RS-232 serial ports;
Application :
It can be used to many fields like security Surveillance, transportation Surveillance, industry Surveillance, home Surveillance. For example:
Network Surveillance for ATM machines, counters in the bank, supermarkets and factories.
Network Surveillance for prisons, kindergartens, and schools.
No-man on duty system for electricity station and telecom base.
Intelligentized gate safeguard system.
Intelligentized building and community management system.
Product-line Surveillance and storehouse management.
24 hours supervising for transportation.
Network Surveillance for forest, waterhead and rivers.
Surveillance for outside devices.
