https://www.radioradar.net/en/news_of_electronic/rs_232.html
Fluke Hart Scientific’s high accuracy temperature/humidity logger has new wireless and Ethernet capability
Optional LogWare III supports Ethernet, 802.15.4 wireless, RS-232, email messaging services and as many “DewKs” as can be put on a network
Hart Scientific, a division of Fluke Corporation and the world leader in temperature calibration products and services, announces the new Hart Scientific 1620A paperless temperature and humidity data logger with wireless, Ethernet, and RS-232 communications.
Designed to facilitate the electronic management of environmental temperature and humidity data, this thermo-hygrometer is intended for environmental monitoring in critical locations such as calibration and research labs, pharmaceutical and chemical storage areas, and many medical environments.
Product information
The Model 1620A – the “DewK” – accepts inputs from up to two sensors, which may be mounted directly on the unit or remotely (up to 30 meters away). The DewK allows sensor hot-swapping and each sensor contains its own calibration data to prevent down time during calibration service. The 1620A comes with a NVLAP-accredited calibration.
Two sensor models are available. The “H” model reads temperature to ± 0.125 °C over its calibrated range of 16 °C to 24 °C. It measures humidity to ± 1.5 % RH from 20 % to 70 % RH. The “S” model reads temperature to ± 0.25 °C over its calibrated range of 15 °C to 35 °C. It records humidity to ± 2 % RH from 20 % to 70 % RH.
In addition to on-board memory which stores up to 400,000 date and time-stamped measurements, data collected by the Hart Scientific 1620A may also be sent directly to a PC in real time using the serial port, Ethernet, or optionally using 802.15.4 wireless communication. By adding Hart Scientific’s LogWare III software, you can simultaneously monitor an unlimited number of instruments. The Windows-based software enables statistical and graphical analysis of real-time or previously recorded data, and can send emails to PDAs, pagers, and mobile/cell phones when triggered by user-defined events.
Source: fluke
