https://www.radioradar.net/en/measurements_technics/matchbox_capacitor_tester.html
Matchbox Capacitor Tester
Checking of an electrolytic capacitor without an LCR meter is not free from hassles. Here is a simple solution for checking the serviceability of a capacitor.
Circuit and working
Fig. 1 shows the circuit diagram of a simple capacitor tester which can be housed in a small matchbox. It is basically an oscillator circuit comprising two transistors, BC558 (T1) and BC548 (T2), and a few other components. The frequency of oscillation, which is in audio range, depends on value of the capacitor under test. The tester can check the serviceability of capacitors in the range of 1μF to 2200μF.
Circuit diagram of the capacitor tester
Fig. 1: Circuit diagram of the capacitor tester
Construction and testing
An actual-size, single-side PCB for the capacitor tester is shown in Fig. 2 and its component layout in Fig. 3.
An actual-size PCB layout for the tester circuit
Fig. 2: An actual-size PCB layout for the tester circuit
Component layout of the PCB
Fig. 3: Component layout of the PCB
Connector CON1 in the circuit is for inserting the capacitor under test. Four-pin berg strip female connector is used here to accommodate different sizes of capacitors. LSI is a small speaker used as headphone (shown in Fig. 4). Assembled PCB of the circuit can be enclosed in a matchbox as shown in Fig. 5.
Earpiece of a headphone
Fig. 4: Earpiece of a headphone
Capacitor tester in matchbox
Fig. 5: Capacitor tester in matchbox
After wiring, do verify that voltages are as per Test Points table.
Test Points
Test point
Details
TP0
0V
TP1
3V
PARTS LIST
Semiconductors :
T1
- BC558 pnp transistor
T2
- BC548 npn transistor
Resistors (all 1/4-watt, ±5% carbon):
R1
- 220-kilo-ohm
R2
- 5.6-kilo-ohm
Capacitor:
C1
- 4.7nF ceramic disk
Miscellaneous:
LS1
- 32-ohm headphone speaker
CON1
- 4-pin connector
BATT.1
- 3V button cell
- 2-pin terminal connector
For testing the capacitor, insert it in CON1. If the capacitor is good, a fire-siren like sound is produced. A continuous beep is produced if the capacitor is short.
Author: Kaushik Hazarika
