https://www.radioradar.net/en/news_of_electronic/wireless_toxic_gas_detector.html
Wireless, wearable toxic-gas detector
MIT researchers have developed low-cost chemical sensors, made from chemically altered carbon nanotubes (CNTs), that enable smartphones or other wireless devices to detect trace amounts of toxic gases.
Using the sensors, the researchers hope to design lightweight, inexpensive radio-frequency identification (RFID) badges to be used for personal safety and security. Such badges could be worn by soldiers on the battlefield to rapidly detect the presence of chemical weapons and by people who work around hazardous chemicals prone to leakage.
“Soldiers have all this extra equipment that ends up weighing way too much and they can’t sustain it,” said Timothy Swager, Professor of Chemistry. “We have something that would weigh less than a credit card. And [soldiers] already have wireless technologies with them, so it’s something that can be integrated into a soldier’s uniform that can give them a protective capacity.”
The sensor is a circuit loaded with CNTs, which are normally highly conductive but have been wrapped in an insulating polymer material that keeps them in a highly resistive state. When exposed to certain toxic gases, the insulating material breaks apart, and the nanotubes become significantly more conductive. This sends a signal that’s readable by a smartphone with near-field communication (NFC) technology, which allows devices to transmit data over short distances.
The sensors are sensitive enough to detect less than 10 parts per million of target toxic gases in about five seconds. “We are matching what you could do with benchtop laboratory equipment, such as gas chromatographs and spectrometers, that is far more expensive and requires skilled operators to use,” Prof Swager said.
Moreover, roughly 4 million can be made from about 1g of the CNT materials. “You really can’t make anything cheaper,” Swager says. “That’s a way of getting distributed sensing into many people’s hands.”
In their study, the researchers drop-cast the nanotube/polymer material onto gold electrodes, and exposed the electrodes to diethyl chlorophosphate, a skin irritant and reactive simulant of nerve gas. Using a device that measures electric current, they observed a 2000% increase in electrical conductivity after five seconds of exposure. Similar conductivity increases were observed for trace amounts of numerous other electrophilic substances, such as thionyl chloride (SOCl2), a reactive simulant in choking agents. Conductivity was significantly lower in response to common volatile organic compounds, and exposure to most nontarget chemicals actually increased resistivity.
To build their wireless system, the researchers created an NFC tag that turns on when its electrical resistance dips below a certain threshold.
Smartphones send out short pulses of electromagnetic fields that resonate with an NFC tag at radio frequency, inducing an electric current, which relays information to the phone. But smartphones can’t resonate with tags that have a resistance higher than 1 ohm.
The researchers applied their nanotube/polymer material to the NFC tag’s antenna. When exposed to 10 parts per million of SOCl2 for five seconds, the material’s resistance dropped to the point that the smartphone could ping the tag. Basically, it’s an “on/off indicator” to determine if toxic gas is present, Swager said.
According to the researchers, such a wireless system could be used to detect leaks in Li-SOCl2 (lithium thionyl chloride) batteries, which are used in medical instruments, fire alarms, and military systems.
The next step, Swager says, is to test the sensors on live chemical agents, outside of the lab, which are more dispersed and harder to detect, especially at trace levels. In the future, there’s also hope for developing a mobile app that could make more sophisticated measurements of the signal strength of an NFC tag.
Tom Austin-Morgan
