https://www.radioradar.net/en/news_of_electronic/bending_current.html
'Bending current' may enable MRAM
MRAM (magnetic random access memory) is faster, more efficient and robust than other kinds of data storage. However, switching bits still requires too much electrical power to make large-scale application practicable. Researchers at Eindhoven University of Technology (TU/e) say they have discovered a way of solving this problem by using a 'bending current'.
MRAM stores data by making use of the 'spin' of electrons. Since magnetism is used instead of an electrical charge, the memory is permanent – even when there is a power failure. These magnetic memories also use less power, which means that battery life can be extended in mobile phones, for example.
In MRAM bits are projected by the direction of the spin of the electrons in a piece of magnetic material: for example, upwards for a '1' and downwards for a '0'. The storage of data occurs by flipping the spin of the electrons over to the correct side. Normal practice is to send an electrical current which contains electrons with the required spin direction through the bit. The large quantity of electrical current needed to do this has hindered a definitive breakthrough for MRAM.
The TU/e physicists’ method is claimed to flip the magnetic bits faster and more energy-efficiently. A current pulse is sent under the bit, which bends the electrons at the correct spin upwards through the bit. "It's a bit like a soccer ball that is kicked with a curve when the right effect is applied," explained Arno van den Brink, TU/e PhD student.
This method is said to be fast, but needs something more to make it reliable. Earlier attempts required a magnetic field, but that made the method expensive and inefficient. The TU/e researchers claim to have solved this by applying an anti-ferromagnetic material to the top of the bits. This is said to enable the requisite magnetic field to be frozen, as it were, making the process more energy-efficient and lowering cost. "This could be the decisive nudge in the right direction for superfast MRAM in the near future," said Van den Brink.
Pic: A magnetic bit is being switched by bending electrons with the correct spin upwards through the bit. A special anti-ferromagnetic material on top of the bits is claimed to make the process reliable
Tom Austin-Morgan
