T&M Tools for Field Engineers
Measurements technics
10 years ago
Being an electronics/electrical field engineer is a challenging job, and for a person engaged in this job T&M tools are just like weapons to a warrior in the war field. in many cases in india, people rely on ‘jugad’tools for a lot of test and measurement activities, but those are neither safe, nor accurate. So presented here are all the must-have tools for an electronics field engineer to perform his jobs safely and accurately.
Field engineers can work in a variety of jobs. They are specialists employed at companies that offer services to clients, and usually work in the field, i.e., locations owned by the client and not by the company at which they are employed. The locations can range from various production facilities and plants to oil fields. In the field, they can act as service representatives, oversee operations, install equipment and maintain and repair the existing equipment or supervise all engineering operations.
A lot of times in India, we see field engineers with strange tools such as a bulb holder connected to two wires for testing the continuity. These tools may do the job but are not safe and accurate. So here we present some basic tools for field engineers and discuss why and how they are used.
Clamp meter
Flow of electrical charge (current) is used to power everything from appliances at home to huge machinery at various industries. In cases where electricity-powered equipment need to be repaired, serviced, maintained or installed, clamp meters can be indispensable tools. A clamp meter is a device that measures various properties of an electrical current. It is a preferable device in the field due to its numerous advantages, including safety, efficiency, versatility and convenience. When clamp meters are used, you do not need to cut any wires, lowering the chances of fatal shocks. Clamp meters can give accurate readings, allowing engineers to quickly diagnose and resolve most problems. Fig. 1 shows a clamp meter.
A clamp meter
Fig. 1: A clamp meter
A clamp meter measures current, voltage, crest factor and continuity. AC current is the primary measurement that a clamp meter should be able to perform. These measurements are taken from different branches of a distributed system to debug the issue.
If an appliance is not working, the first thing to check is the input supply. Most clamp meters are capable of reading AC and DC voltages. These meters can also read crest factor which refers to the measurement of a waveform. The crest factor value is determined by the waveform's peak value versus its RMS value and is important in determining whether a circuit is overloaded. Continuity can also be checked using a clamp meter and the same is indicated with a beeprs. Table I shows various clamp meters available from different manufacturers.
TABLE I. Clamp Meters from Different Manufacturers
Specifications
Fluke Fluke 362
Agilent U1211A
HIOKI 3288-20
Metrix+ Mod: 4250T
IDEAL 61-775
AC current
Range
200A
40A/400A/400-700A/700-1000A
100/1000A
1000A
0.0-999.9A
Resolution
0.1A
0.01A/0.1A/1A
0.1A (100A range)
1A
Accuracy
2% ±5 (45-65Hz)
2.5% ±5 (65-400Hz)
1.0 % +5 (400-1000A)
1.5% ±5 digits
2% ±5 digits
2%
DC current
Range
200A
40A/400A/1000A
100/1000A
1000A
0.0-999.9A
Resolution
0.1A
0.01A/0.1A/1A
0.1A (100A range)
1A
Accuracy
2% ±5 digits
1.5% ±5 digits
2% ±5 digits
2%
AC voltage
Range
600V
400V/1000V
4.2/42/420/600V
400mV-700V
0.0-750.0V
Resolution
0.1V
0.1V
0.001V (4.2V range)
1V
Accuracy
1.5% ±5 (45-400Hz)
1 % ±5 digits
2.3% ±8 digits
1.5% ±5 digits
1%
DC voltage
Range
600V
400V
420m/4.2/42/420/600V
400mV-1000V
0.0-999.9V
Resolution
0.1V
0.1 V
0.1mV (420mV range)
1V
Accuracy
1% ±5 digits
0.5% ±5 digits
1.3% ±4 digits
1% ±3 digits
1%
Resistance
Range
300/3000Ω
4000/ 4kΩ
420-41.99MΩ
400Ω-40MΩ
0.0-999.9 0hm
Resolution
0.1/10
0.1Ω/0.001kΩ
0.1Ω (420Ω range)
10kΩ
Accuracy
1% ±5 digits
0.5% ±3 digits
2% ±4 digits
1.5% ±5 digits
2%
Continuity
≤700
Yes
Yes
Yes
Yes
Dimensions
205x60x22mm
106x273x43mm
57x180x16mm
249x89x38mm
270x103x48.5mm
Clamp opening
18mm
52mm
35mm diameter
52mm
51mm
Weight (gm)
196
625
150
360
500 (including battery)
Safety reading
CAT III 600V
CAT III 1000V/CAT IV 600V
CAT III 600V (current) CAT III 300V (voltage)
IEC 61010-1
CAT IV, CAT III
Insulation resistance tester
Eighty per cent of electrical maintenance and testing involves evaluating insulation integrity. Harsh installation environments, especially those with extreme temperatures and/ or chemical contamination, cause deterioration to the insulations and, as a result, personnel safety and power reliability can suffer.
So it is important to identify this deterioration as quickly as possible so you can take the necessary corrective measures. Fig. 2 shows an insulation resistance meter.
Insulation resistance meter
Fig. 2: Insulation resistance meter
To test the insulation, we apply a highly regulated, stabilised DC voltage across a dielectric and measure the amount of current flowing through that dielectric, and then calculate the insulation resistance using Ohm's law. The current here is the leakage current and the resistance is in mega ohms. This value of resistance is used to evaluate the integrity of the conductor.
Generally, positive and negative leads are put across an insulation barrier. A third lead, which connects to a guard terminal, may or may not be available with every tester. After the connections are made, test voltage is applied for a minute, which is a standard industry parameter that allows you to make relatively accurate comparisons of readings from past tests done by other technicians. During this interval, the resistance reading should drop or remain relatively steady.
Larger insulation systems will show a steady decrease, whereas smaller systems will remain steady because the capacitive and absorption currents drop to zero faster than on larger systems. After one minute, you should read and record the resistance value. Table II shows insulation resistance testers from different manufacturers.
TABLE II. Insulation Resistance Testers from Different Manufacturers
Specifications
Fluke Fluke 1507
IDEAL Model: 61-797
HIOKI IR4056-20
Metrix+ DIT 3125
Insulation secifications
Measurment range
1507: 0.01MQ-10GΩ
Up to 20GΩ
Up to 4000MΩ
0-1000GΩ
Test voltage
50V, 100V, 250V, 500V, 1000V
30-600V
Test voltage accuracy
+20%, -0%
0-20%
2% ±5 digits
2% ±3 digits
Short circuit current (mA)
1mA nominal
1mA nominal
1.2mA or less
1.3mA
Auto discharge
Discharge time <0.5 seconds for C = 1μF or less
Discharge time <1 second for C <1μF
Yes
Yes
Maximum capacitive load
Operable with up to 1μF load
Not specified
AC 1200V/10 sec
Measure accuracy
±3% +5 (below 100V)
4%
>100GΩ ±20%
Earth-bond resistance measurement
Range
20Ω/200Ω/2000Ω/20kΩ
10-1000Ω
Resolution
0.01Ω/0.1Ω/1.0Ω/0.01kΩ
0.01 ohm to 40.00 kΩ
0.01 Q (10Ω range)
Accuracy
±(1.5% +3)
3% ±2 digits
Overload protection
2V RMS or DC
600V AC RMS/DC
600V AC
Open circuit test voltage
>4.0V, <8V
>4.0V, <8V
4.0V to 6.9V
>200.0mA
>200.0mA
200mA or more
Safety
Complies with ANSI/ISA 82.02.01 (61010-1) 2004, CAN/ CSA-C22.2 NO. 61010-1-04, and IEC/EN 61010-1 second edition for measurement category IV 600V (CAT IV)
Complies with UL/IEC/EN 61010-1, 61010-031, EN61557, EN 61326-1 +1A (EMC) Cat IV-600V
CAT III 600V
IEC 61010-1
IP rating
IP40
IEC 60529 (IP40)
Dimensions
203x100x50mm
207x95x52mm
159x177x53mm
153x213x95
mm
Weight (gm)
550
630
600
1030
Earth ground tester
A proper grounding system is of huge importance in the industrial and home environment. Proper grounding of metallic enclosures and support structures that are part of the electrical system helps avoid fatal shocks due to any kind of electrical system failure. The grounding system also provides protection against static electricity from tribocharging. Another important use of grounding system is protection against direct lightning strokes.
It is estimated that at least 15 per cent of the power quality problems are related to improper grounding. Therefore good grounding ensures that these problems do not escalate. Fig. 3 shows an earth ground tester and table III shows the testers from different manufacturers.
Earth ground tester
Fig. 3: Earth ground tester
TABLE III. Earth Ground Testers from Different Manufacturers
Specifications
Fluke Fluke 1621
Metrix+ Model: DET 1503
IDEAL 61-920
General specifications
Measuring functions
Three-pole earth ground resistance, two-pole AC resistance of a conductor, interference voltage
0.00-2000Ω
Ground resistance, ground leakage current
Measuring rate
Two measurements/second
5sec/V 2sec
0/120/1200Ω
Safety
IEC/EN 61010-1, 600V CAT II, pollution degree 2
IEC 61010-2­031
IEC61010-1: 2001 (CAT IV 300V Pollu­tion degree 2), IEC61010-2-032: 2002
IP rating
IP 40; IEC/EN 60529
IEC60529 (Ip54)
IP 40
Dimensions
113x54x216mm including holster
170x120x79mm
246x119x53mm
Weight (gm)
850
675
771
Electrical specifications
Test voltage
3.7kV
0-200V
Measuring time
8 seconds (average from when start is pressed)
10 sec-10 min
Electromagnetic compatibility
Emission: IEC/EN 61326 Class B, Immunity: IEC/EN 61326 Annex C
Yes
Interference voltage display
Vmax 30Veff
Common mode rejection >80dB at 50Hz and 60Hz Ri 680kΩ
Measuring uncertainty <10% for pure AC and DC signals
Yes
Yes
Measuring range resolution
Resolution 0.01Ω, display range 0-19.99Ω
0.01Ω
Resolution 0.1Ω, display range 20-199.9Ω
0.1Ω
Resolution 1Ω, display range 200-1999Ω
RE resistance measurement
Open circuit voltage (Vac)
23V to 24V AC
220V
>50mA AC
1.3mA
0.1mA
Measuring frequency (Hz)
128Hz
50/60Hz
2400Hz
Permissible overload (Veff)
250Veff
300V AC 30 seconds
Laser distance meter
Laser distance meter can be a very useful tool for measuring distances with good precision without physical contact. In fact it allows for the most sensitive and precise length measurements, faster recordings encompassing large ranges. All these qualities do not come with a single technique so different techniques are used based on specific requirements. Some of the most important techniques used for laser distance meters are as follows:
1. Triangulation is a geometric method, useful for distances in the range of a millimetre to many kilometres.
2. Time-of-flight measurements (or pulse measurements) are based on measuring the time-of-flight of a laser pulse from the measurement device to some target and back again. Such methods are typically used for large distances.
3. The phase-shift method uses an intensity-modulated laser beam. Compared with other techniques, its accuracy is lower, but it allows unambiguous measurements over larger distances and is more suitable for targets with diffuse reflection.
4. Frequency modulation methods involve frequency-modulated laser beams, for example, with a repetitive linear frequency ramp. The distance to be measured can be translated into a frequency offset, which may be measured via a beat note of the sent-out and received beam.
Fig. 4 shows a distance meter.
Distance meter
Fig. 4: Distance meter
Vibration tester
Machines are used in nearly every aspect of our daily life; from the vacuum cleaner and washing machine we use at home, to the industrial machinery used to manufacture nearly every product we use on a daily basis. When a machine fails or breaks down, the consequences can range from financial loss, personal injury and possible loss of life. For this reason, early detection, identification and correction of problems is paramount to anyone involved in the maintenance of industrial machinery to ensure continued, safe and productive operation.
Vibration levels give a very good idea of the state of a machine. It is evident from the fact that we naturally touch a rotating machine and feel the vibrations to see if it is running right. Even machines in the best of operating condition will have some vibration because of small, minor defects. Therefore each machine will have a level of vibration that may be regarded as normal or inherent. However, when vibration increases or becomes excessive, some mechanical trouble is usually the reason. Various instruments have been developed to actually measure a machine's vibration level and assign it a numerical value. Fig. 5 shows a vibration meter and Table IV shows features of some vibration meters from different manufacturers.
Vibration meter
Fig. 5: Vibration meter
TABLE IV. Vibration Meters from Different Manufacturers
Specifications
Fluke Fluke 805
MetrixTM Model: VB 8202a
MCM Instruments vibration tester AVD - 80
Extech Instruments Extech 407860
Range
Low frequency
10Hz-1000Hz
10Hz
10Hz
10Hz
High frequency
4000Hz-20,000Hz
1000Hz
1000Hz
1000Hz
Vibration limit
50g peak (100g peak-peak)
0.1-4000Ω
200mm/s
Sample rate
Low frequency
20,000Hz
10Hz
High frequency
80,000Hz
1000Hz
Signal-to-noise ratio
 80dB
Sensor
Sensitivity
100mV g ±10%
Piezoelectric
Measurment range
0.01g-50g
0.1-400.0 m/s
Resolution
0.01g
0.1mm/s
0.5m/s2, 0.5mm/s, and 0.05mm
Safety
Accuracy
At 100Hz ±5% of measured value
5% ±2 digits
±(2% + 0.1mm/s)
±5% ±2 digits
IP rating
IP54
Dimensions
241x71x58mm
140x70x30mm
180 x 72 x 32mm
Weight (gm)
1160
150
200
395
These are all the basic equipment that a field engineer would need depending on the project at hand. You can also add a multimeter to the list, which is also a useful tool in many cases. Refer buyers' guide on handheld digital multimeters published in Feb ruary 2013 issue for details.
Author: Ankit Gupta
Opinions of readers
There isn't comments. Your comment will be first.
You can make comments about current:
Required fields
