Distance Counter
Measurements technics
9 years ago
Distance Counter
Presented here is a simple pedometer circuit. It measures the distance covered by you while walking. It may not work very well for running!
Circuit and working
Fig. 1 shows circuit diagram of the distance counter. The circuit is built around quad 2-input Schmitt trigger CD4093 (IC1), CMOS ripple carry binary counter/divider CD4024 (IC2), decade counter/divider CD4026 (IC3 and IC4), two transistors BC327 (T1, T2) and some other components.
Fig. 1: Circuit diagram of the distance counter
Gates N1 and N2 of IC1 form a monostable multivibrator that receives trigger input from tilt or mercury switch S1. When you lift your foot up and touch the ground back during walking, the mercury inside the switch makes a contact with its two metallic leads as shown in Fig. 2. This makes the current to flow between the metallic leads and a pulse is generated at pin 4 of IC1.
Open-close operation of mercury switch
Fig. 2: Open-close operation of mercury switch
Test Points
Test point
Details
TP0
GND, 0V
TP1
+3V when power switch S3 is closed
TP2
High when reset and remains high till 64 counts and low for the next 64 counts
TP3
Low to high when both S4 and S5 are pressed simultaneously
TP4
High when S5 is pressed to display the reading
This pulse is fed to pin 1 of IC2 that produces a divide-by-64 counter. Its output is given to inputs of gate N4 of IC1 and the output of N4 is fed to the base of transistor T2 through resistor R8. Transistor T2 drives the decimal point segment of common cathode 7-segment display (DIS1).
IC3 and IC4 are configured as decade counters to drive the 7-segment displays DIS1 and DIS2, respectively. Switch S4 resets these two counters and switch S5 enables DIS1 and DIS2 displays.
Transistor T1 drives the piezobuzzer (PZ1), which beeps after every two steps (one stride), provided switch S2 is closed. DIS1 and DIS2 displays indicate the distance covered in metre (m) and kilometre (km) units, respectively.
Generally, walking step of each individual is slightly different. Here, we assume that a single step is 78cm long, which is the average. According to this, 64 strides equal 100m (that is, 2×0.78×64=99.84m or 100m (approx.)) or 128 steps equal 100m.
DIS1 increments the digit after every 100m distance. That is, DIS1 displays 1 when distance covered is 100m and 2 when distance covered is 200m, and so on. After digit 9 in DIS1, DIS2 increments from 0 to 1 digit. The decimal point (dot) of DIS2 always glows to indicate separation of kilometre from the metre unit.
To save battery power consumption, DIS1 and DIS2 displays illuminate only when you push S5. If you want to reset the counter circuit, both switches S4 and S5 must be pressed simultaneously.
If you want to continuously illuminate DIS1 and DIS2 displays, remove switch S5 and connect the junction of S4 and emitter of transistor T2 to 3 V.
Parts List
Semiconductors :
IC1
- CD4093 quad 2-input NAND Schmitt trigger
IC2
- CD4024 counter/divider
IC3, IC4
- CD4026 decade counter/divider
T1, T2
- BC327 pnp transistor
Resistors (all 1/4-watt, ±5% carbon):
R1, R3
- 22-kilo-ohm
R2
- 2.2-mega-ohm
R4
- 1-mega-ohm
R5, R7, R8
- 4.7-kilo-ohm
R6
- 47-ohm
R9, R10
- 1-kilo-ohm
Capacitors:
C1
- 47nF ceramic disk
C2
- 330nF tantalum
C3
- 10nF ceramic disk
Miscellaneous:
DIS1, DIS2
- LTS543, 7-segment CC display
PZ1
- Piezo buzzer
S1
- Tilt/mercury switch
S2, S3
- On/off switch
S4, S5
- Tactile switch
CON1
- 2-pin terminal
- 3V battery
Construction and testing
An actual-size, single-side PCB for the distance counter is shown in Fig. 3 and its component layout in Fig. 4.
Fig. 3: An actual-size, single-side PCB for the distance counter
Component layout for the PCB
Fig. 4: Component layout for the PCB
Mount DIS1 to the right of DIS2 as shown in the PCB so that you get proper readings. For example, if DIS2 shows 5 and DIS1 shows 2, the reading will be 5km and 200m. It means the distance travelled is 5200m.
After assembling the circuit on PCB, enclose it in a suitable plastic case so that you can keep it in your trouser's pocket or attach it to your belt.
Use 2-pin connector CON1 for 3 V battery in the PCB. Also fix switches S2 through S5 on the front side of the case.
The author is an electronics hobbyist.
Author: Yogesh Shukla
Opinions of readers
There isn't comments. Your comment will be first.
You can make comments about current:
Required fields
